Date/Time: Wed, 27 Nov 2024 03:53:17 +0000
TPO IB range
View Count: 361
[2023-09-18 16:57:12]
User547290 - Posts: 58
I want to set the TPO chart value profile for the IB in Points rather than tics. Is there a way to do this?
imageDimmer_fDhCxlK0KY.png / V - Attached On 2023-09-18 16:56:52 UTC - Size: 16.65 KB - 87 views
[2023-09-18 18:04:57]
John - SC Support - Posts: 36309
There is not a way to do this directly in the TPO Chart. You would have to use another chart for the same symbol and use the "Initial Balance" study to get the High and Low of the Initial Balance. Then you can use the Arithmetic Studies or a Spreadsheet Formula or Spreadsheet to calculate the Initial Balance in Points.
You can then overlay that to your TPO study chart and have it in another region. You can set it to display at Text and set the range for the scale to be very large so the numbers are all aligned.
Refer to the following for the individual pieces referenced above:
Initial Balance
Using the Basic Arithmetic Studies
Spreadsheet Formula
Overview of Spreadsheet Studies
Study/Price Overlay Study
Chart Studies: Value of Subgraph (ACSIL: DRAWSTYLE_VALUE_OF_SUBGRAPH)
[2023-09-21 04:16:39]
OK, that sounds like it could work, I'll give it a try.
