Date/Time: Wed, 27 Nov 2024 04:41:46 +0000
Font size with SC version 2547
View Count: 280
[2023-09-18 16:08:48] |
User223231 - Posts: 17 |
Hi, i just downloaded version 2547 of SC and there seems to be something off with fonts. Specifically, the font size in the price and time scale of a chart seems much smaller than expected. It also does not match the preview in the global graphics / font settings. https://www.sierrachart.com/image.php?Image=1695053310756.png |
Screenshot 2023-09-18 090513.jpg / V - Attached On 2023-09-18 16:05:29 UTC - Size: 234.32 KB - 101 views Attachment Deleted. |
[2023-09-18 17:37:03] |
John - SC Support - Posts: 36309 |
This is being looked into. Roll back to the version you had previously (Help >> Install Previous Version) for now.
[2023-09-18 19:06:34] |
Thank you.
[2023-09-19 16:47:28] |
Sierra_Chart Engineering - Posts: 17190 |
Refer to this post: Changes to Font Size Handling within Sierra Chart | Post: 358505 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
