Date/Time: Mon, 16 Sep 2024 19:50:20 +0000
Pulling stacking not updating on STOCKS_MBO
View Count: 336
[2023-09-18 09:55:02] |
BenjFlame - Posts: 324 |
Hi, the image attached shows a chart's DOM. On the left you can see chart market depth displaying total ask levels. On the right, red numbers, you can see pulling/stacking DOM column. You can see that the 11.8k ask level, doesn't have pulling stacking, yet it was variating. Shouldn't the pulling/stacking column, reflect those variations? I observe this all kind of stocks such as TTOO_MBO |
bidaskpullstack.png / V - Attached On 2023-09-18 09:53:13 UTC - Size: 3.55 KB - 102 views |
[2023-09-19 17:25:57] |
Sierra_Chart Engineering - Posts: 16387 |
We will do some checking on this.
[2023-11-11 09:21:32] |
User769783 - Posts: 166 |
So is there plling and stacking for MBO Stocks? Which datafeed would I need to get the data? Thanks
[2023-11-13 06:16:55] |
Yes you have to use NASDAQ TotalView, for pulling and stacking data. More details here: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-13 06:17:03
