Date/Time: Wed, 27 Nov 2024 04:50:21 +0000
Eurex instruments not showing correct data on expiry date
View Count: 373
[2023-09-18 02:01:38] |
User494557 - Posts: 3 |
Hi, I am currently with AMP futures, and I am using Denali data feed, with CQG order routing. I have noticed for DAX and Eurostoxx50, on the new December contract, when I choose continuous contracts in the chart settings, it is currently not showing the correct data for the expiry day, which was this past Friday (15/09/23). Only the first half of the day is shown. But when I change it to non-continuous contracts, it displays the data correctly. Please see images below Dax Continuous vs. Non-continuous: https://www.sierrachart.com/image.php?Image=1695001950868.png https://www.sierrachart.com/image.php?Image=1695002091503.png Eurostoxx Continuous vs. Non-continuous: https://www.sierrachart.com/image.php?Image=1695002339823.png https://www.sierrachart.com/image.php?Image=169500238729.png Date Time Of Last Edit: 2023-09-18 02:09:07
[2023-09-18 16:15:41] |
John - SC Support - Posts: 36309 |
We see that these are different charts. What are the session times set to in both charts?
[2023-09-19 03:06:56] |
Session time is set to 0800-1730 on both charts. Actually I've managed to get around the issue, by using volume based rollover instead of date based rollover. Not sure why this is, but I guess I'll use this from now on. |
[2023-09-19 10:00:57] |
Sierra_Chart Engineering - Posts: 17190 |
We are looking this over. We may need to make an adjustment to the date-based rollover rules.
[2023-09-19 16:53:09] |
Refer to: Missing data EUREX | Post: 358489 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
