Date/Time: Mon, 16 Sep 2024 19:25:22 +0000
Chart Background Color
View Count: 1820
[2014-07-15 20:23:47] |
User72407 - Posts: 31 |
Is there a way to change the chart background to some other color than white? TX
[2014-07-15 21:00:07] |
Yes. Refer to Graphics Settings here: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
