Date/Time: Wed, 27 Nov 2024 04:46:35 +0000
[Locked] - Quote Board Not Updating
View Count: 289
[2023-09-17 23:00:20]
User417302 - Posts: 67
After updating to version 2547, the quote boards are not updating high/low, day change/% day change? Everything is showing as a zero.
Why would this have happened and how can I resolve?
Thanks,
[2023-09-18 00:39:32]
Sierra_Chart Engineering - Posts: 17190
You definitely should be seeing:
high/low
We do not observe any problem with these.
The daily price change related fields will be zero for CME futures due to an issue on the CME side.
[2023-09-18 00:57:12]
Is this only affecting the Denali feed? I don't see this issue across any other platform.
[2023-09-18 01:05:07]
What issue specifically? The high/low are fine.
[2023-09-18 01:11:18]
Correct, hi/lo are fine. But daily change both $ & % are at zero.
[2023-09-18 01:38:22]
This is definitively a CME exchange issue. We have confirmed that. Not a Sierra Chart problem. We cannot comment about this problem with any other program.
[2023-09-18 01:40:12]
Ok, fair enough.
