Date/Time: Wed, 27 Nov 2024 04:53:52 +0000
QoS for Denali & Teton
View Count: 490
[2023-09-17 17:28:45] |
binaryduke - Posts: 369 |
I'd like to set up QoS prioritisation on my router for Denali and Teton. Please can you advise for Denali & Teton: - the service type (TCP; UDP; TCP/UDP; - the associated port numbers Thanks. |
[2023-09-17 19:00:48] |
Sierra_Chart Engineering - Posts: 17190 |
It is TCP. And the port numbers you can see in the Window >> Message Log. There are different port numbers used. They are shown when you select File >> Connect to Data Feed, or Reconnect.
