Date/Time: Wed, 27 Nov 2024 02:31:10 +0000
Help
View Count: 1014
[2014-07-15 18:53:55] |
julian pineda - Posts: 60 |
I want to make a study: a simple mathematical difference. What i Want its to make a window with: (last candle AskVolume - current BidVolume). so what i need to know is that difference in %. can you help me? |
[2014-07-15 19:05:58] |
For this we recommend using the Spreadsheet Study: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
