Date/Time: Wed, 27 Nov 2024 04:50:19 +0000
volume/bid ask in reply. Chart Dom
View Count: 265
[2023-09-17 02:11:02]
MSHN - Posts: 1
Hi, I have question about two different issues(:
Chart DOM is not showing the resting orders correctly (live session), see attached video. DOM works okay on IBRK tradestation(I have level2 data from IBRK)
Second is that when I turn on volume or bid/ask indicator in market reply it does not show anything. Is there some setting that needs to be changed to save the volume and bid/ask data for market reply
Private File
[2023-09-18 15:43:37]
John - SC Support - Posts: 36309
We do not know why this would be occurring. Our only suggestion is to ensure that you are on the most recent "Stable" version of TWS and on the most recent version of Sierra Chart (2547).
You can update your Sierra Chart by using the following instructions:
[2023-09-19 17:27:47]
Sierra_Chart Engineering - Posts: 17190
Sierra Chart provides no technical support for this at all:
You need to use Sierra Chart data for this:
You need to use this data feed:
Denali Exchange Data Feed
You are able to use it with Interactive Brokers. Refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Date Time Of Last Edit: 2023-09-19 17:28:59
