Date/Time: Wed, 27 Nov 2024 04:30:45 +0000
[User Discussion] - How to Easily, Partially Extend Smaller Rectangles
View Count: 274
[2023-09-16 21:40:21]
User708541 - Posts: 87
I'm an avid rectangle drawer. Many times I want to simply click and 'drag to extend' a rectangle to the right or left. WITHOUT CHANGING THE RECTANGLE'S HEIGHT. However, many times, on rectangles with a low height, they simply wont extend without also changing the rectangle's height. This is not good and messes up the vertical alignments I've worked so hard to set up.
On rectangles that are taller and there are more dots along a vertical line to grab, the rectangle extends without changing the height. But this should be possible when less dots are present as well.
I want to keep my chart's vertical axis as is, and simply extend a 'low height' rectangle right or left.
Can you please add this functionality to SC?
BTW: Right Click 'Extend' does not solve this, as that feature extends the rectangle to infinity. I want to extend to the distance of my choosing.
