Date/Time: Wed, 27 Nov 2024 04:46:03 +0000
sc.GetSymbolDataValue Question
View Count: 232
[2023-09-16 18:23:09] |
User1293821 - Posts: 42 |
double marketOpen = sc.GetSymbolDataValue(SYMBOL_DATA_TRADING_STATUS); SCString marketOpenString; marketOpenString.Format(" - MarketOpen Value: %f", marketOpen); The markets are closed now and for some of those markets I get 3.00 and others 0.00. I tried with BTCUSDT-Binance which is open and also get 0.00 The documentation I did see looks behind. https://sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scGetSymbolDataValue Can you update to what the values should return? Thanks. |
[2023-09-17 13:42:17] |
Sierra_Chart Engineering - Posts: 17190 |
Trading Status is not supported at all, for crypto currencies. Getting a value of zero would make sense.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-17 13:42:31
