Date/Time: Wed, 27 Nov 2024 04:33:08 +0000
v2547
View Count: 411
[2023-09-15 20:27:06]
User585104 - Posts: 142
I'm not sure what has happened but this version, the text on the scale and the time at the bottom is like 2mm in size now. GFX font settings are all still correct
[2023-09-17 15:29:16]
So even if you increase the font size to around 22 so it matches every other font in SC (10), it makes the time scale misaligned so there is now a black needless line under the scroll bar. Also in the chart header a line appears pushing the text lower
[2023-09-17 15:31:06]
If I turn openGL off the fonts remain the correct, all the correct size of 10
[2023-09-17 16:05:15]
Sierra_Chart Engineering - Posts: 17190
We will be looking into this.
[2023-09-19 18:42:07]
v2549 works perfectly again.
[2023-09-19 19:26:42]
That is good to know.
