Date/Time: Wed, 27 Nov 2024 04:56:37 +0000
v2547 font size & alignment issues
View Count: 346
[2023-09-15 19:34:17]
hyp0luxa - Posts: 18
After updating from 2543 to 2547, all Text Display studies including Clock had reduced font size. Prior to update I had size set to 14, after update I had to change size to 24 to appear the same
Also similar issue for Volume By Profile - Display Volume & Number Bars text. Had to double the font size. Text is unreadable in Number Bars no matter what I do. Seems like an alignment issue.
I am running OpenGL if that matters
[2023-09-15 19:59:50]
Chart fonts are also affected, if an attempt to change them is made
[2023-09-18 14:32:55]
John - SC Support - Posts: 36309
Did you by any chance change monitors during this time so that there is a different DPI for the monitor?
[2023-09-18 14:46:33]
no, monitor is the same, gpu, drivers all the same. I reverted back to 2543 and these issues are no longer present
[2023-09-18 17:31:21]
There is an issue that is being looked into.
