Date/Time: Thu, 10 Sep 2026 13:42:46 +0000
historical data of BTC-e.com
View Count: 1641
| [2014-07-15 17:07:15] |
| User19479 - Posts: 25 |
some questions There is not too much historical data of BTC-e.com , how to add more data? and Will you add Alt coin exchange sites ? such as Mintpal.com Cryptsy.com ? Thanks |
| [2014-07-15 18:53:23] |
How much historical data are you currently getting for BTC-e.com? How much historical data do you require and for what symbol? It is not likely we would be adding support for Mintpal.com Cryptsy.com . We recommend referring them to the open specification protocol that Sierra Chart supports for market data and trading: DTC Protocol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-15 18:54:01
