Date/Time: Wed, 27 Nov 2024 04:53:57 +0000
[Programming Help] - How can i set more CPU to SC
View Count: 344
[2023-09-15 18:25:53] |
MrTienDatVn - Posts: 13 |
My program show up SC use only 1 core to analyst, how can i set all CPU core for SC run faster? Thank you. Date Time Of Last Edit: 2023-09-15 18:26:24
Screenshot_17.png / V - Attached On 2023-09-15 18:25:41 UTC - Size: 43.92 KB - 80 views |
[2023-09-15 19:02:47] |
John - SC Support - Posts: 36309 |
You would need to run multiple instances of Sierra Chart to take advantage of multiple cores. Refer to the following: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
