Date/Time: Mon, 16 Sep 2024 19:07:48 +0000
Chart Dom Column: Current Trade Total Volume get reset in case of an fill on Evaluation
View Count: 275
[2023-09-15 17:04:58] |
User230940 - Posts: 121 |
Hello, since yesterday in test the Evalutation Mode, which is great and provide a very good real Live environment. Thanks. But I get a strange behaviore of my existing environment. I am trading on the DOM and I have modified the DOM Column via customization. Im use using the Column "Current Trade Total Volume". With an open Filled, the "Current Trade Total Volume" will be reseted. I add two Images of ES Future Contract: 1. Image before files https://www.sierrachart.com/image.php?Image=16947906484.png 2. After Filled https://www.sierrachart.com/image.php?Image=1694790735117.png Where can I configure this behavior? Thanks for your feedback regards |
[2023-09-15 18:24:28] |
John - SC Support - Posts: 34450 |
Refer to the following: Global Trade Settings Windows: Clear Current Bid/Ask Volume on New Position (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-19 06:35:56] |
THanks perfekt.
