Date/Time: Wed, 27 Nov 2024 04:49:14 +0000
Why does the size/resolution of my two TPO charts look different?
View Count: 286
[2023-09-15 04:51:05] |
reknirt - Posts: 8 |
I have two different TPO charts for oil futures. Each chart uses the same tick size but one (purple/blue) appears much more crisp and higher resolution than the other (white w/ shaded VA) which has bigger boxes that are more bunched up, etc. I am trying to get the one with the bigger/bunchier box size to look like the other but I have no idea what is causing this variance. I've attached screenshots for clarity. Thank you! https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=86866 https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=86867 |
little.png / V - Attached On 2023-09-15 04:48:13 UTC - Size: 202.85 KB - 95 views Attachment Deleted. |
[2023-09-15 14:51:44] |
John - SC Support - Posts: 36309 |
Most likely is the Input for "Letter/Block Price Increment in Ticks" that is different between these. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-15 16:12:58] |
They are the same on both charts -- 2 ticks. All of the settings look the same. Are there window zoom/resolution settings that could be doing it?
[2023-09-15 17:52:56] |
Definitely the range of the scale will have an impact on the view of the profiles. Refer to the following for how to adjust the scale: Chart Scale and Scale Adjusting: Interactive Scaling For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-15 18:55:12] |
I figured it out. It was the spacing b/t the bars. Pressing the down arrow and reducing the spacing improved it dramatically. Thank you.
