Date/Time: Wed, 27 Nov 2024 02:43:34 +0000
Russell 2K stocks datafeed
View Count: 324
[2023-09-14 20:07:31]
ramsoft2003 - Posts: 6
I recently purchased Nasdaq total view data feed and I am not seeing Russell 2K stocks under it.
I am looking for ticker symbols such as Nesco Holdings, Inc.(NSCO) , Viela Bio, Inc, (VIE), Builders FirstSource, Inc.  (BLDR) etc and could not find under NASDAQ/NYSE/AMEX category.
Is it from a different exchange which is not supported by SC?
Let me know.
-Ram
[2023-09-24 09:31:50]
Sierra_Chart Engineering - Posts: 17190
First, you need to update Sierra Chart to the current version:
Make sure you are using the correct symbols.
One of the symbols you mention is no longer in existence. Check all of them to make sure they are actually valid because if you get no data for a particular symbol, then it simply does not exist currently.
All current and in existence NYSE, AMEX, and NASDAQ stock symbols are supported. Just manually type the symbol like this into the Find Symbol window.
GM-NQTV
Refer to:
File Menu: Find Symbol (File)
Date Time Of Last Edit: 2023-09-24 09:33:32
