Date/Time: Wed, 27 Nov 2024 04:44:28 +0000
I want ZigZag to Start at the Day Session Not Eve Session!
View Count: 360
[2023-09-14 18:22:16] |
J DIDDY - Posts: 132 |
Hi I want the ZigZag Start time to be the Day Session (14.30pm - NY Open in the UK) Not the Eve Session (11pm - NY Close in the UK) BUT even though it is set to 'Start at a new day' in the Study prefs - because I'm using the 'Evening Session' in the Chart Settings/Session times, it starts my ZigZag at 11pm. When I take off the 'Evening Session' in the Chart Settings, then it uses the 14.30pm time. I need to be able to keep my evenings sessions ON but I want the ZigZag to start at the day session of 14.30 pm (UK) I have the line set to 'Skip Zeros' - which also shows me the changeover of the study from one session to the next. Please see screens attached. Thx |
ZigZag Starts at Day Session.jpg / V - Attached On 2023-09-14 18:20:49 UTC - Size: 1.44 MB - 84 views ZigZag Starts at Eve Session.jpg / V - Attached On 2023-09-14 18:20:57 UTC - Size: 1.44 MB - 100 views Zigzag Study Setting.jpg / V - Attached On 2023-09-14 18:21:03 UTC - Size: 1.61 MB - 103 views |
[2023-09-14 18:47:39] |
John - SC Support - Posts: 36309 |
To do what you want you would have to have another chart that is set to just be the Day Session, and add the Zig Zag study to that chart. Then use the Study/Price Overlay on the 24 hour chart to get the Zig-Zag onto the 24 hour chart without the evening session. Just be aware that since the labels are actually drawings, you will not be able to get these onto the 24 hour chart, you will only be able to see the zig zag line. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-14 23:07:49] |
ok, Thanks John
Date Time Of Last Edit: 2023-09-14 23:08:00
