Date/Time: Wed, 27 Nov 2024 04:44:49 +0000
Split file export by day
View Count: 265
[2023-09-14 16:37:46]
Flo_O - Posts: 4
Dear Sierra team,
would it be possible to create a little feature like a checkbox to split the 'export bar & study data to text file' by day so we have multiple smaller ones? Everything the same, just with your usual date format before the .txt
This would be a huge quality of life feature for me, because then the columns of each file are already set & performance to work with a small file is much better...
Or if there is a way in ACSIL I would be more than happy as well :)
Thank you so much!
Florian
[2023-09-14 17:00:13]
John - SC Support - Posts: 36309
The format for the Intraday Data files can be found at the following link:
Intraday Data File Format
You can create your own program to parse the data and export as you wish.
