Date/Time: Wed, 27 Nov 2024 04:58:32 +0000
How do I display back the crosshair with the small cross in the center?
View Count: 515
[2023-09-14 11:41:50] |
User22085 - Posts: 11 |
Hello, I tried to find info about that on Support Board and SierraChart webside, but no success so far. Currently, when I choose Crosshair from Tools menu it appears along with an arrow. I would like to have the Crosshair allong with the small cross in the center, not the arrow. Thank you. |
[2023-09-14 13:47:10] |
JohnR - User831573 - Posts: 306 |
You can right click with the Pointer over a chart window to display a menu of commonly used commands. See attached for Crosshair selection. Hope this helps, JohnR |
SC_Crosshair2023-09-14_09-43-07.png / V - Attached On 2023-09-14 13:46:57 UTC - Size: 141.11 KB - 120 views |
[2023-09-14 14:21:57] |
I did it, but I have an arrow next to the horizontal and vertical lines. Instead, I used to have the small cross (haircross);
Image 014.png / V - Attached On 2023-09-14 14:21:00 UTC - Size: 25.12 KB - 92 views |
[2023-09-14 14:42:41] |
John - SC Support - Posts: 36309 |
That is an operating system setting. Refer to the following: https://www.tomsguide.com/how-to/how-to-change-mouse-cursor-in-windows-10 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-14 15:04:45] |
I would not like to change the pointer of the whole operating system from an arrow to a crosshair, but to the SC only. By the way, I've just opened an older instance of SC (ver. 2247), which I didn't used for a long time and the pointer is still a crosshair in there. On my main SC instance (ver. 2502), however, the pointer remains an arrow. I did run a Windows update the other day, so might have this caused pointer appearance change in SC ver2502, but not in SC ver2247? Could it be some other SC settings that I missed? |
[2023-09-14 16:15:39] |
Sierra Chart does not have a specific setting for this. The software just picks up the setting for a particular pointer type from the operating system.
