Date/Time: Wed, 27 Nov 2024 06:49:31 +0000
Highest High/Lowest Low Over N Bars
View Count: 400
[2023-09-14 11:17:08]
User137942 - Posts: 10
Hello, i use the Highest High/Lowest Low Over N Bars Study and i want that it shows just a horizontal line in all the chart just at the last value so that in the chart i have just 1 line for the high and 1 line for the low of the N days but displayed in all the chart.
Thanks for your time
[2023-09-14 14:32:19]
John - SC Support - Posts: 36309
Set the Subgraph "Draw Style" to "Line at Last Bar Left to Right". Refer to the following:
Chart Studies: Line at Last Bar Left to Right (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_LEFT_TO_RIGHT)
There are a few other Line drawing options, so if the above is not exactly what you want, see if one of the others may do it.
