Date/Time: Wed, 27 Nov 2024 06:48:20 +0000
[Programming Help] - Can't Erase Drawn Volume Profile
View Count: 263
[2023-09-14 02:18:48]
User734575 - Posts: 3
This has happened multiple times. Some of my volume profiles that I have drawn won't erase even though I click erase all drawn market profiles. It will erase some but not all. Now I have 2 stuck over each other that can't be erased.
[2023-09-14 13:55:22]
John - SC Support - Posts: 36309
Most likely a modification was made to them such that they are no longer considered "Drawn Volume Profiles". As such, they are just standard Volume at Price Profiles and you can remove them by selecting "Analysis >> Studies" and then remove them from the list of "Studies to Graph". Refer to the following:
Chart Studies: Remove (Analysis >> Studies)
