Date/Time: Wed, 27 Nov 2024 04:52:42 +0000
Printing Chart Crashes Sierra
View Count: 260
[2023-09-13 20:32:07]
User933497 - Posts: 12
I have done this 5 or 6 times....it does the same every time:
I go to file and print to print a chart. It prints just fine (the first time).
However, if I try to print another chart, it freezes Sierra. I have to use task mgr to close it.
When I restart Sierra, it prints fine the first time. But it always crashes Sierra the second time I try to print a chart.
Can anyone help?
[2023-09-14 02:52:07]
Sierra_Chart Engineering - Posts: 17190
We are not able to reproduce this and we are not sure what the issue is in your case.
One thing you can do is try printing to a PDF document and print the PDF and see if that works around the problem.
Date Time Of Last Edit: 2023-09-14 02:52:16
[2023-09-20 01:39:14]
We want you to update to the latest release:
And see if that resolves the printing problem in your case.
We may have discovered what is causing this.
