Date/Time: Wed, 27 Nov 2024 06:48:53 +0000
How to Display the Study Only
View Count: 503
[2023-09-13 19:09:08]
moveupwithmike - Posts: 25
I have a couple indicators that I only want to show the indicator and not the price graph as I lay out my charts. I have gone into Chart -> Graph Draw Type and chose blank. I also went into Chart settings -> Display and said no display Main Price graph.
The price is gone but the right price scale is still there.
I also have some hidden indicators that the third chart area is there blank and cant get rid of it. No right price scale for this.
Thanks in advance,
https://www.sierrachart.com/image.php?Image=1694633746551.png
Date Time Of Last Edit: 2023-09-13 19:38:35
imagesample chart.png / V - Attached On 2023-09-13 19:38:15 UTC - Size: 6.64 KB - 78 views
[2023-09-13 20:48:44]
John - SC Support - Posts: 36309
The easy solution is to adjust the region sizes so you can minimize the ones that you do not want. Refer to the following:
Working With Charts: Chart Window and Regions
The more complicated solution is to enable the option for "Use as Main Price Graph", which will then set that study to be displayed in Region 1. But you have to be a bit careful with this, as another study will then use that as the basis for its data. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph
