Date/Time: Wed, 27 Nov 2024 06:47:06 +0000
Previous day High/Low study?
View Count: 444
[2023-09-13 19:02:15] |
HeyUgly - Posts: 247 |
Is there any study in the default sierra library that will plot a horizontal line at previous day High/Low areas? I know session times would need to be defined etc but is there a study that exists?
[2023-09-13 20:42:43] |
John - SC Support - Posts: 36309 |
Daily OHLC. It allows you to define the Number of Days Back that it will calculate for. Refer to the following: Daily OHLC And you can turn off the Open and Close subgraphs if you do not want them by setting the Draw Style to Ignore or Hidden. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
