Date/Time: Tue, 26 Nov 2024 12:45:47 +0000
Large Volume Trade Indicator - Can it do This?
View Count: 386
[2023-09-13 14:23:38] |
User708541 - Posts: 87 |
Is there a way to have a transparent circle AND text on or near the transparent circle? Whenever I try to have the trade size text show with a transparent circle, the circle loses its transparent quality and goes solid. Thanks for assistance with this.
[2023-09-13 15:53:07] |
John - SC Support - Posts: 36286 |
There is not a way to do what you are asking for.
[2023-11-26 17:11:41] |
mastox - Posts: 1 |
I am also interested in this. Is there any plan to support this at some point? Thank you. |
[2023-11-26 20:23:08] |
Sierra_Chart Engineering - Posts: 17179 |
You can definitely display a marker and the volume text at the same time. This is supported.
