Date/Time: Mon, 01 Jul 2024 03:58:12 +0000
[User Discussion] - Calculation time
View Count: 246
[2023-09-13 03:03:41] |
User843179 - Posts: 7 |
I understand calculation time per chart is the total of calculation for all studies in that chart. However what I want to know is, is that calculation time one-off at the opening of the chart? Or is it constant, eg the same calculation time will apply on every new bar in the already opened chart. So for example, if I have a long lookback z-score with 3000ms calculation time and a total calculation time of all studies = 5000ms, when the current bar closes with an colour bar by alert triggered, will it take 5000ms for the closed bar to be coloured? Thanks |
[2023-09-13 17:20:37] |
Tony - Posts: 485 |
@User843179 Couple of questions, 1, where does calculation time displayed? 2, what is 'long lookback z-score'? 3, what time frame you are using, and how many days of data you are loading? btw, if calculation time you mentioned is study's full recalculation time, then 5 seconds is way too long, and not usable, to put it into perspective: the full recalculation time of a custom study I am using right now is 4 ms |
