Date/Time: Wed, 27 Nov 2024 06:29:18 +0000
Static chart on update of candlesticks?
View Count: 230
[2023-09-12 15:06:43]
PRRV - Posts: 1
Is there a way I can stop the chart from moving to the left at every new candle that is created? I trade on short timeframes and it is very difficult to draw trendlines while the chart (tick or renko) itself is moving very fast. Thank you in advance for your answers. :)
[2023-09-12 17:00:26]
John - SC Support - Posts: 36309
There are two options for this:
1) Have the chart scrolled forward so that you can not see the new bars being added.
2) Have the chart scrolled back so that there is open space to the right, where the bars will then fill in as they are added. You will have to occasionally scroll the chart back when the bars get to the right side.
With this, also make sure the following setting is set to "Yes":
General Settings Window: Allow New Data In Unlocked Fill Space (Global Settings >> General Settings >> Charts >> Charts)
