Date/Time: Wed, 27 Nov 2024 06:34:07 +0000
Needhelp index name
View Count: 279
[2023-09-12 13:56:28] |
ABBES - Posts: 4 |
Hello, in my DOM, I have the letter M that appears on the side of the name of the index. Could you please tell me what it is and how to remove it? Thanks in advance. |
Capture d'écran 2023-09-12 152955.png / V - Attached On 2023-09-12 13:56:23 UTC - Size: 13.89 KB - 72 views |
[2023-09-12 16:29:58] |
John - SC Support - Posts: 36309 |
The [M] means that you are getting the data for that symbol from our data feed. It can not be removed. Refer to the following: Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-12 19:24:47] |
ABBES - Posts: 4 |
Hello, thank you for your reply. However, when I open a DOM from a graph. The DOm (BID/ASK) data are not the same. On the other hand if I open it from the menu "OPEN TRADING DOM" and looking for the same symbol the data is the same. Why such a difference? Thank you; |
[2023-09-12 20:41:29] |
We need to see images of what you are referring to in order to understand what you are seeing. Please get us images by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-12 20:47:34] |
ABBES - Posts: 4 |
you can see the red circle the differences beetwenn 2 DOM for the same contrat.
Capture d'écran 2023-09-12 224442.png / V - Attached On 2023-09-12 20:46:12 UTC - Size: 238.54 KB - 67 views |
[2023-09-12 20:52:24] |
You have the "Trade and Current Quote Symbol" set for both of these charts. For each of them, you need to check the setting for "Use as Trade Only Symbol" and see if this is set the same for both of these. We are guessing that it is not set the same, in which case the chart that has that option set to "No" is showing the Market Depth data for the symbol set as the "Trade and Current Quote Symbol" and the other one is showing the Market Depth for the primary symbol. Refer to the information here: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-12 21:01:17] |
ABBES - Posts: 4 |
You are right thank you for your help.
