Date/Time: Wed, 27 Nov 2024 06:41:05 +0000
cumalative delta bars - value label static intabar
View Count: 234
[2023-09-12 13:03:50]
tradermartn5 - Posts: 3
I have added study "cumalative delta bars" and enabled "value label" and it displays ok, but price label is static intrabar and only updates at end of bar period. Is it possible to enable it to update dynamically in real-time like a standard chart's value label?
[2023-09-12 16:24:40]
John - SC Support - Posts: 36309
The Value Label will update whenever the value it is referencing changes. Make sure you have set the "Close" subgraph to show the Value Label, as the other items do not update as often.
[2023-09-12 16:38:19]
Brilliant, fixed! Thank you!
