Date/Time: Wed, 27 Nov 2024 06:48:19 +0000
quote board linked to charts
View Count: 385
[2023-09-12 12:57:34] |
Boris Libman - Posts: 58 |
I've recently added a quote board with the idea of linking it to a historical and intraday charts for the instruments I have on the quote board. I've found that the responsiveness (clicking on different symbol) with the link is significantly slower than when I disable the link, presumably having to reload the data for the associated chart. Which settings on my chart data download should I toggle to improve performance? |
[2023-09-12 16:20:51] |
John - SC Support - Posts: 36309 |
We are not sure exactly what you are wanting, but if the issue is that when you select an item on the Quote Board, you want to then have a chart for that symbol, then the solution for downloading the data is the following: Global Settings Menu: Intraday File Update List (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-12 17:14:00] |
Again, when I link the quote board to a (historical daily) chart, each time I click on a different instrument, the chart takes several seconds to update the data, which makes switching between instruments clunky. Will adding the symbols of instruments on my quote board to the Intraday File Update List alleviate that?
[2023-09-12 18:30:28] |
This is going to be the case for Historical Daily charts and there is not a way to work around it. The Intraday File Update List will resolve the issue for Intraday charts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
