Date/Time: Tue, 26 Nov 2024 23:31:52 +0000
Support
View Count: 454
[2023-09-11 23:23:58] |
User175868ZZA - Posts: 21 |
I have 3 issues highlighed below; I have attched a picture attachment. I am getting this message regarding symbol needs roll over. I have followed steps in this article below but it has not worked. [volume] symbol needs rollover Also, I am having issues with changing the order fill color on this chart, I have tried to do it follwoing this article below, but still was not able to; Entry and Exit Prices (Order Fills on Chart) Lastly, I see a red number in the bottom right corner in attached image, how can this be removed? |
Capture.PNG / V - Attached On 2023-09-11 23:23:55 UTC - Size: 17.12 KB - 86 views |
[2023-09-11 23:28:01] |
John - SC Support - Posts: 36309 |
Follow the instructions at the following link to roll over the contract:Changing to a New Futures Contract Month: Changing to a New Futures Contract Month Also, I am having issues with changing the order fill color on this chart, I have tried to do it follwoing this article below, but still was not able to;
You need to change the Graphics Settings for the order fills. Refer to the information starting at the following link:Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Order Fill Buy Entry Lastly, I see a red number in the bottom right corner in attached image, how can this be removed?
You can not remove this. Refer to the following for information on what this tells you:Working With Charts: Chart Settings Indicators at Lower Right of Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-14 17:19:50] |
Thanks. How do I change the colour on the table in new picture. I just need to the minu -delta sum colour to appear like the above red numbers.
Capture.PNG / V - Attached On 2023-09-14 17:18:42 UTC - Size: 6.45 KB - 85 views Attachment Deleted. |
[2023-09-14 17:25:13] |
Since the -Delta Sum values are positive numbers, you can not get them colored red. Unless, you want to change all positive values to be red. To change the positive values to red you would need to change the "Range # Up Colors" to be reds and not greens. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-20 15:41:10] |
Hi, on the Dom picture, how can I change the total number in bid & offer column to larger font and different colour? Also on the other picture of footprint, when zoomed out it is not showing the latest info in the delta, CD day & percent change column. It is only showing to the second last bar in picture. How can this be fixed. I have to zzom right in for it to appear. Thanks
Capture.PNG / V - Attached On 2023-09-20 15:39:19 UTC - Size: 32.26 KB - 68 views |
[2023-09-20 16:23:43] |
The control for the color of the Bid/Ask Totals is the Graphics Setting for "Chart DOM [Trade DOM] Total/Percentage Text". Refer to the information here for the Chart DOM setting (there is a separate entry for Trade DOM): Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Total/Percentage Text With regards to the Numbers Bars Calculated Values, the issue is that you have the labels displayed on the right, therefore they are covering that last bar's information. There are a few solutions: - Change the labels to display to the left by setting the Input for "Labels on Right" to "No". - Change the Input for "Allow Values to Overlap Labels" to "Yes". - Use shorter names for the labels by entering a "Short Name" for each subgraph. - Use the "Lock Fill Space" option so the data does not go into that area. - Scroll the chart back just a bit so you can see that data. Refer to the following for references to the above: Numbers Bars: Numbers Bars Calculated Values Input Descriptions Chart Studies: Settings and Inputs Tab >> Short Name Working With Charts: Right Side Fill Space For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-25 14:11:37] |
Hi, in the attached picture how can I change the text size of volume within the dom, left side of dom? Also do you know why there is a white box within the dom aswell?
Capture.PNG / V - Attached On 2023-09-25 14:11:26 UTC - Size: 20.15 KB - 81 views |
[2023-09-25 18:05:06] |
We assume that the numbers to the left are a Volume by Price study. If it is, then you change the size of the text through the Subgraph for the "Volume Numbers Text Color and Size". Refer to the following: Volume By Price Study: Volume Numbers Text Color and Size (SG7) One of the white boxes at the current price is the Last Trade Price Box. The other boxes are most likely the "Trade DOM Best Bid/Ask Box Background". Refer to the following: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Best Bid/Ask Box Background For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-27 16:13:48] |
Ok, where do I exactly need go to change the text size? Is this global settings. Can you provide the setting I need to go into?
Date Time Of Last Edit: 2023-09-27 16:13:59
[2023-09-27 19:54:08] |
In the Volume by Price study, the volume text size and color in the bars is controlled by Subgraph 7 (Volume Number Text Size and Color). Refer to the following: Chart Studies: Subgraphs Tab For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-03 20:17:49] |
Hi, When I load my saved template, it loads as in the picture is their anyway I can change so this does not happen each time? |
2222222222222222222.PNG / V - Attached On 2023-10-03 20:17:42 UTC - Size: 45.64 KB - 68 views |
[2023-10-03 23:00:06] |
Sierra_Chart Engineering - Posts: 17187 |
Do you mean a Study Collection that uses the Volume by Price study, then causes the chart to reload? This is because it requires volume at price data which was not previously loaded. There is no way to avoid this unless you keep some volume at price related study on the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-05 19:18:22] |
Ok, but its loading the same data each time, going back to 2020?
[2023-10-09 20:46:10] |
If it is loading data back to 2020, then that is because that is how you have your chart setup. Refer to the following: Chart Settings: Data Limiting For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
