Date/Time: Sun, 20 Sep 2026 00:56:51 +0000
[Programming Help] - GetSpreadsheetSheetHandleByName Path Not Working in Acsil
View Count: 766
[2023-09-11 19:39:03]
User584005 - Posts: 30
I'm trying to reference a spreadsheet using the full path/extension but I can't seem to get it to find the file.
I know I can use the file name only without the extension but I want to be able to reference files in places other than the Data Folder.
For example if I have
const char* SheetCollectionName = "C:\\SierraChart\\Spreadsheets\\Tickers.scss";
const char* SheetName = "Sheet1";
void* SheetHandle = sc.GetSpreadsheetSheetHandleByName(SheetCollectionName, SheetName, false);
The sheet will be not be recognized. The only way it will is if i put the sheet in the Data folder and change the code to
const char* SheetCollectionName = "Tickers";
When I referenced ACSILSpreadsheetInteraction.cpp, it had a comment saying
  // This can either contain a complete path and file extension, or just
  // the name of the spreadsheet file itself without the extension.
Am I misunderstanding or coding this incorrectly?
