Date/Time: Wed, 27 Nov 2024 04:55:51 +0000
Questions about OrderStatusCode
View Count: 352
[2023-09-11 17:34:41]
WeroTrader - Posts: 46
Greetings, Sierra Chart team.
The reason for my query is to know what the SCT_OSC_UNSPECIFIED constant refers to.
of the OrderStatusCode in automated trading systems.
I have been having orders with this status and would like to know how to correct them. Apparently it happens to me when there are limited exit options. And this causes me to not be able to track if an internal order id has been fulfilled
Without further ado for the moment and thanking you in advance, I look forward to your comments or guidance to consult documentation.
[2023-09-12 17:39:06]
Sierra_Chart Engineering - Posts: 17190
Exactly how are you getting orders with this status:
SCT_OSC_UNSPECIFIED
An order would never have this status.
[2023-09-18 18:05:42]
thanks for the reply.
I'm trying to program a grid strategy.
The entire strategy is based on placing both sell and buy limit orders; at a specific distance from each other.
I start by placing two entry orders, a short and a long. Then I track each one through the order status so that, when (either of the two) has a filling status, I can place an exit order for it.
It happens that when I follow up on the second order (the outgoing one), its status returns as SCT_OSC_UNSPECIFIED even though they have been filled in, which causes the rest of my logic to stop working.
[2023-09-18 21:49:50]
It is possible that the order is actually no longer available. Check the return value of the function getting the order to see if it has succeeded.
Refer to:
Automated Trading From an Advanced Custom Study: Getting Order Information
Date Time Of Last Edit: 2023-09-19 17:24:48
