Date/Time: Wed, 27 Nov 2024 07:28:48 +0000
Transfer Sierra Chart Files
View Count: 270
[2023-09-11 15:39:24]
navickas_deividas - Posts: 6
I'm reinstalling Windows on the same PC Sierra was installed on. What is the correct procedure to transfer all the settings and data to a fresh new install of Windows? Is it just copy paste the installation folder or is there a set of folders or files that is enough to do that? I want to transfer my chartbooks and settings. Market Depth data isn't necessary.
Thank you
[2023-09-11 18:05:48]
John - SC Support - Posts: 36309
There are a few options, just depending on what you want to do. Refer to the options at the following link:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
