Date/Time: Wed, 27 Nov 2024 07:31:03 +0000
Quoteboard Weekend Data Zeroed Out
View Count: 206
[2023-09-10 17:42:28] |
user_xyz - Posts: 416 |
Is there a setting allowing the Quoteboard to retain values from Friday close so all the fields are not zeroed out. It seems something has changed didn't use to be this way. It's helpful over the weekend doing research to see values. NQTV stock quotes are all zero Last, Change, DailyChange etc Futures Contracts are varied with many fields zeroed out like Open Interest, Volume, Last etc. |
Attachment Deleted. Private File |
[2023-09-10 22:08:50] |
Sierra_Chart Engineering - Posts: 17191 |
No there is no setting like that. Sometimes particular quote board fields can be zero for one reason or another over the weekend. You need to rely on Charts for past historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
