Date/Time: Wed, 27 Nov 2024 07:52:57 +0000
Apex trader funding
View Count: 648
[2023-09-09 17:30:31] |
User227841 - Posts: 2 |
Bonjour, j'ai plusieurs questions. Lors de l'achat de mon compte sur Apex trader, dois-je acheter aussi le Denali data feed ou alors est-il fourni par Apex ?? Et dois-je aussi acheter le pack CBOT non professionnel (3$ par mois ). Et la connection sur sierra chart est expliqué sur votre article mais elle reste relativement simple ? Merci pour vos réponses Cordialement Manoux |
[2023-09-11 15:13:25] |
John - SC Support - Posts: 36309 |
From Google Translate: I have several questions. When purchasing my account on Apex trader, do I also need to purchase the Denali data feed or is it provided by Apex? And should I also buy the non-professional CBOT pack ($3 per month).
And the connection to Sierra Chart is explained in your article but it remains relatively simple? You do not NEED to purchase the Denali Exchange Data Feed in order to use Sierra Chart with Rithmic, as you can get the data from Rithmic. But there is a lack of historical data and we do not give help with Rithmic data issues. Refer to the following: Rithmic Trading Platform Service: Rithmic Market Data and Support Policy Therefore, we do highly recommend using our Denali Exchange Data feed instead of the Rithmic data. To setup this data, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Just be aware that in order to get the CME Group data at the non-professional rates, you need to have a live, funded, futures trading account to which you can connect your Sierra Chart software for verification. A Prop Firm account like APEX, does not work to satisfy this requirement. Refer to the following for more information: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account that will satisfy the above, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement In order to connect to Rithmic, follow the instructions at the following link: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
