Date/Time: Wed, 27 Nov 2024 02:28:40 +0000
system rollover date wrong?
View Count: 629
[2023-09-08 17:50:55] |
Berliner JFK - Posts: 45 |
I set my rollover date to always be the Friday before expiration in symbol settings, i.e. "7 calendar days before the 3rd Friday of the contract month". For /NQU23, for example, that would be Sept. 8th (today). Please see attached, this is what I see in symbol settings now. Is this correct? If not, could you please tell me what went wrong? Thanks! |
rollover_mismatch.jpg / V - Attached On 2023-09-08 17:49:58 UTC - Size: 133.89 KB - 133 views |
[2023-09-08 18:10:58] |
John - SC Support - Posts: 36309 |
The setting is "Number of Calendar Days from the 3rd Friday". 7 calendar days back from a Friday is a Saturday. You need to change this to 8 to get the previous Friday.
[2023-09-08 18:55:04] |
Hi John, thanks! Please see attached. For NQU23, the calculated rollover date is Saturday, September 9th, 2023, which is wrong (7 calendar days before Sept. 15th is Sept. 8th, not the 9th). For NQU24, the calculated rollover date is Friday, September 13th, 2024, which is right (7 calendars days before Sept. 20th is Sept. 13th, is correct). I have also used this setting for three past rollovers, and it never before calculated a Saturday as seven calendar days before a Friday. Given the above, it seems like something has to be wrong with the rollover dates for NQU23, right? Thanks again! Date Time Of Last Edit: 2023-09-11 11:09:51
NQU23_saturday.jpg / V - Attached On 2023-09-11 10:57:22 UTC - Size: 183.25 KB - 106 views NQU24_friday.jpg / V - Attached On 2023-09-11 10:57:30 UTC - Size: 183.16 KB - 103 views Attachment Deleted. |
[2023-09-11 11:09:05] |
Here are all the contracts listed in symbol settings: NQU23 - wrong (shows saturday as seven calendar days before friday) NQZ23 - wrong " NQH24 - wrong " NQU24 - right (shows friday as seven calendar days before friday) NQZ24 - right " I attached screenshots from NQH24, NQU24 and NQZ24 for more proof. Thanks! |
NQH24_saturday.jpg / V - Attached On 2023-09-11 11:06:38 UTC - Size: 181.56 KB - 112 views NQM24_friday.jpg / V - Attached On 2023-09-11 11:06:56 UTC - Size: 183.67 KB - 99 views NQU24_friday.jpg / V - Attached On 2023-09-11 11:07:06 UTC - Size: 183.16 KB - 107 views |
[2023-09-12 15:01:21] |
Sierra_Chart Engineering - Posts: 17190 |
We will look this over.
[2023-09-12 15:05:33] |
Thank you!
[2023-09-29 15:23:10] |
Update to the latest release to resolve this.
[2023-10-01 01:06:00] |
Rollover dates correct now, thank you!
