Date/Time: Wed, 27 Nov 2024 07:46:11 +0000
[Programming Help] - Adjust chart drawings by futures rollover amount
View Count: 267
[2023-09-08 16:43:06]
Alex C Demosthenes - Posts: 50
With the ES rollover to the forward date, I would like to roll my chart drawings over by the same amount that symbol rollover will happen. I know about using "Adjust" in the manage chart drawings window, but I want them all to rollover over to the new contract amount without me having to type in the amount to roll them over by, since it's not fixed right now.
I have tried to perform rollover with drawings but they stay at the old contract amount. I have tried to perform the rollover without the drawings and then click Chart > Update Drawings to Current Symbol, but they don't update that way either. I have opened the Manage Drawings window and tried to adjust each drawing to the new contract, but that does nothing. The only option I can find is to manually enter a number into each adjustment window, but I'm not even sure what the exact amount is.
Is there not any way to adjust them when the contract is rolled over?
