Date/Time: Wed, 27 Nov 2024 07:28:41 +0000
Point and Figure drawings copied to time based charts
View Count: 227
[2023-09-08 03:04:14] |
User180397 - Posts: 15 |
I am able to copy drawings between point and figure charts with the same symbol without issue. I have a time based chart and a P&F chart, with the same symbol, I'd like to share drawings between. I'm able to copy a vertical line from either the P&F or time based chart to the other chart. I am not able to copy over any horizontal lines, rectangles, etc. in either direction - time to P&F or P&F to time. Can you refer me to the documentation on the nuances of copying between chart styles and or time frames? Is there a path to enable this ability between P&F and time based charts, or other work around? Regards, Bob M |
[2023-09-08 14:39:13] |
John - SC Support - Posts: 36309 |
There should not be any major issue with copying the drawings between the charts. The only real issue is simply the way that drawings are copied, in that the anchor points are placed on the nearest bar that has the same time and of course the prices are matched up. Therefore, if the times for a drawing from one chart fall within the time span of a single bar on another chart, then you will not see the drawing. Refer to the following for more information: Chart Settings: What to Do If Chart Drawings Do Not Copy For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
