Date/Time: Wed, 27 Nov 2024 06:29:13 +0000
[User Discussion] - Entries and exits off
View Count: 221
[2023-09-07 15:52:18]
Shink22 - Posts: 6
Hello, I had to close a trade outside of sierra chart because my wifi went down and now my entries and exits are off by 1. Sierra chart doesn't see the exit for the position I closed when my wifi was down so it thinks my next entry/exit was the close of that last open position and has continued to be off for the last 3 or 4 days. Does anybody know how to fix this? Thank you.
https://www.sierrachart.com/image.php?Image=1694101791613.png
[2023-09-07 16:03:56]
John - SC Support - Posts: 36309
Refer to the following:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities
