Date/Time: Sun, 24 Nov 2024 11:09:38 +0000
Missing Stocks
View Count: 426
[2023-09-07 14:44:25]
User115547 - Posts: 3
I wanted to add stocks to my chart so I purchased the real-time data feed for the Nasdaq. However, when I went to go add Broadcom INC. (AVGO), Costco (COST), and Adobe (ADBE), I couldn't find them in the "Find Symbol" menu in Sierra Charts. What do I need to do in order to have access to these stocks. Thank you for your help.
[2023-09-07 15:11:22]
You just have to type them in. Not all the stocks can be listed as there are far too many of them.
Since you have setup the NASDAQ TotalView exchange, when you type in the symbol, it needs to have a '-NQTV' suffix added in order to tell our system that you want the NASDAQ TotalView data. For example, for AVGO, you would enter AVGO-NQTV. Refer to the information at the following link:
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes
If you are trading direct from Sierra Chart, then you will need to use the "Trade and Current Quote Symbol" in order to set the correct symbol for your trading service. Refer to the following:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
[2024-06-02 20:15:15]
User566250 - Posts: 37
I am trying to find specific symbols (NVDL, CONL, FNGU, etc.) and they are not listed in the "Find Symbol" menu. I cannot seem to be able to type them using my keyboard since I am using my keyboard for shortcuts and the alphabets programmed for the shortcut do not do anything when I try to type the symbols. Please advise.
Thank you
[2024-06-03 15:44:57]
We are not understanding what you are trying to say. As noted in post #2, you need to type in the name of the symbol you want in the "Selected Symbol" field on the "File >> Find Symbol" window. We do not list all the symbols in the list of symbols for stocks, as there are too many to list.
[2024-06-03 20:11:18]
Sierra_Chart Engineering - Posts: 17154
Full documentation for this:
File Menu: Searching for Symbols
