Date/Time: Wed, 27 Nov 2024 00:48:26 +0000
Unable to connect to Data feed
View Count: 948
[2014-07-14 15:03:26]
rhovega - Posts: 279
Dear Sierra,
Today, having changed nothing on my side, I have been unable to connect to your data feed. Getting the error message below. I believe the problem is on your side. Either way, please help.
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-07-14 10:58:53
Using username 0 | 2014-07-14 10:58:55
SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-07-14 10:58:55
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-07-14 10:58:55
Error received in OnConnect while connecting. Windows error code 10038: An operation was attempted on something that is not a socket. | 2014-07-14 10:59:13
HD Request # 5 - Error downloading historical Intraday data for CL-201408-NYMEX. The network socket has been closed. Retrying download. | 2014-07-14 10:59:13
HD Request # 5 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CL-201408-NYMEX | 2014-07-14 10:59:13
HD Request # 5 - Intraday download COMPLETE for CL-201408-NYMEX | 2014-07-14 10:59:13
Real-time Intraday chart data file updates started for CL-201408-NYMEX | 2014-07-14 10:59:13
Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-07-14 10:59:16
SC Exchange Data: Disconnected from the server. | 2014-07-14 10:59:16
SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 10:59:16
Using username 0 | 2014-07-14 10:59:18
SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-07-14 10:59:18
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-07-14 10:59:18
Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2014-07-14 10:59:39
SC Exchange Data: Disconnected from the server. | 2014-07-14 10:59:39
SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-07-14 10:59:39
Using username 0 | 2014-07-14 10:59:41
SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-07-14 10:59:41
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-07-14 10:59:41
Warm regards,
K
[2014-07-14 15:21:07]
We are aware of this problem. Please refer to post #14 here:
NOTICE: Sierra Chart Exchange Data Feed Was Down | Post: 37740
Date Time Of Last Edit: 2014-07-14 15:21:20
