Date/Time: Wed, 27 Nov 2024 06:32:45 +0000
Major Problem SOME windows don't let price scale adjust
View Count: 271
[2023-09-07 13:15:20]
TopGunTrader - Posts: 172
Either this is a bug or a new feature I don't know about that needs changed. Most of my charts work however some I can not use scroll wheel to move window up/down like all others and when I click on price scale to zoom in out like all other charts work they do not work it does nothing. This is driving me nuts as so many charts I rely on I can't zoom in/out or move window up/down like the rest do and work.
[2023-09-07 15:05:10]
John - SC Support - Posts: 36309
It sounds like those charts have the Interactive Scale option set to "Interactive Scale Locked".
Right-click on the price ladder (scale) and see what the Interactive Scale options at the top of the list is set to. If you want to be able to move the scale around, then it should NOT be set to the locked option - set it to whichever of the other 2 works best for you. Refer to the following:
Chart Scale and Scale Adjusting: Interactive Scaling
