Date/Time: Wed, 27 Nov 2024 07:37:32 +0000
Resource problem with drawings from other charts
View Count: 246
[2023-09-07 12:32:38]
Trader-6767 - Posts: 3
Dear Ladies and Gentlemen,
I have noticed several times now that when I transfer drawings from e.g. M15 to another chart in Sierra Charts, the resources of the computer go up massively and a reasonable work is no longer possible. If I hide the Drawings, the resources go back to a normal level. I have noticed this now with several, different chartbooks.
I have recorded a small video of the complete procedure to make this problem clear for you.
In this example we are talking about 29 draws (retangles, retangles ext. with a fill (Transparency 0%)).
I use the software only as a charting module, but even for that the further use doesn't make sense for me.
Can you let me know a solution to the problem?
Thank you very much for feedback.
Best regards
W. Schmidt
Private File
[2023-09-11 04:06:50]
Sierra_Chart Engineering - Posts: 17191
Are you sure there are only 29 drawings? Check the source chart, by going to Window >> Manage Chart Drawings Window and see how many drawings there actually are.
Try hiding each individual drawing and try to determine what drawing is causing a problem.
Problems like this, really relate to the operating system. Not Sierra Chart.
