Date/Time: Wed, 27 Nov 2024 06:37:55 +0000
CDT Text
View Count: 246
[2023-09-07 11:34:55]
User98657 - Posts: 327
A future upgrade suggestion:
It would be great if we could add text to a CDT. For instance, I use CDTs to post Horizontal Rays on a chart that is posted on a community server. After plotting the levels, I have to then go back into the line and use >>Modify Text to add text to each of these lines that are posted individually. It would help if I could save these lines to my buttons with the text saved in the Tool Config I use for each of these CDTs.
Thank you!
[2023-09-07 14:39:00]
John - SC Support - Posts: 36309
If the text is consistent (the same thing for a specific line) then you can set a Configuration Name for a specific configuration and in the Properties set the option for "Copy Config Name to Text", which will then use the Configuration Name as the text for that line. Refer to the information for this item in this section:
Chart Drawing Tools: Common Tool Configuration Settings and Chart Drawing Properties
