Date/Time: Wed, 27 Nov 2024 07:47:52 +0000
SPX500 Not working
View Count: 320
[2023-09-07 08:52:05] |
Alv P - Posts: 37 |
Hi support, SPX500 is not updating since yesterday 9-6 |
[2023-09-07 12:05:51] |
Sierra_Chart Engineering - Posts: 17191 |
We see updates for this symbol. No problems at all. No missing data. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-08 11:55:34] |
Alv P - Posts: 37 |
Solved with updating from server button Thank you! |
