Date/Time: Wed, 27 Nov 2024 06:41:17 +0000
Random disconnections log attached
View Count: 270
[2023-09-07 08:27:46]
rshimmin - Posts: 42
I keep getting disconnected then reconnects at random times. Here is the log:
Triggering next historical data download in queue. | 2023-09-07 08:47:15.054
HD Request # 75 | Downloading Intraday chart data for 6CU23-CME to the file 6CU23-CME.scid. Service: cme | 2023-09-07 08:47:15.054
HD Request # 75 | Download start date-time: 2023-09-07 08:46:13.000000. File last date-time: 2023-09-07 08:46:13.922000 | 2023-09-07 08:47:15.056
HD Request # 75 | Using server: ds26.sierracharts.com port 10149 | 2023-09-07 08:47:15.056
Socket (2) | Creating socket. | 2023-09-07 08:47:15.056
Socket (2) | New receive buffer size: 5242880 | 2023-09-07 08:47:15.056
Socket (2) | Connecting to IP: 142.215.17.188. | 2023-09-07 08:47:15.056
Socket (4) | Socket gracefully closed by remote side. | 2023-09-07 08:47:15.150
Socket (4) | Closed. | 2023-09-07 08:47:15.150
HD Request # 75 | Setting DTC encoding to Binary VLS | 2023-09-07 08:47:15.323
HD Request # 75 | Sending historical data logon request message. | 2023-09-07 08:47:15.323
DTC Client socket (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-09-07 08:47:15.656 *
DTC Client socket (3) | CloseSocket call. | 2023-09-07 08:47:15.657
DTC Client socket (0) | CloseSocket call. | 2023-09-07 08:47:15.657
Denali Data Feed | Disconnected from the server. | 2023-09-07 08:47:15.657
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-09-07 08:47:15.657
DTC Client socket (3) | Closed. | 2023-09-07 08:47:15.657
HD Request # 75 | Requesting Intraday data. Start date-time: 2023-09-07 08:46:13. Record interval: 0. Symbol: 6CU23 | 2023-09-07 08:47:15.962
HD Request # 75 | Decompressing data. | 2023-09-07 08:47:16.085
HD Request # 75 | Receiving Intraday data for 6CU23-CME starting at 2023-09-07 08:46:13.922000 | 2023-09-07 08:47:16.208
Socket (2) | CloseSocket call. | 2023-09-07 08:47:16.209
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-09-07 08:47:16.209
Historical data download thread signaled to stop. | 2023-09-07 08:47:16.209
HD Request # 75 | Timestamp of first Intraday data file record written: 2023-09-07 08:46:16.728000. | 2023-09-07 08:47:16.210
HD Request # 75 | Received 51 Intraday data records from 2023-09-07 08:46:13.922000 to 2023-09-07 08:47:11.321000 (57.4 seconds. Delay: 4.9 seconds) and wrote 50 records for 6CU23-CME | 2023-09-07 08:47:16.210
HD Request # 75 | Add time&sales data | Remembered last file record date-time: 2023-09-07 07:47:11.321000 | 2023-09-07 08:47:16.226
HD Request # 75 | Completion time: 1s. | 2023-09-07 08:47:16.226
HD Request # 75 | Intraday data download complete for 6CU23-CME. Unique request ID: 58 | 2023-09-07 08:47:16.226
Removing historical data download ID 58. | 2023-09-07 08:47:16.226
Real-time Intraday chart data file updates started for 6CU23-CME | 2023-09-07 08:47:16.226
Intraday chart data file opened for 6CU23-CME | 2023-09-07 08:47:16.226
HD Request # 75 | Enabling Intraday chart updating for symbol. | 2023-09-07 08:47:16.226
[2023-09-07 12:03:26]
Sierra_Chart Engineering - Posts: 17190
This is not within Sierra Chart control. It has to do with the network connectivity that you have. Refer to:
Data/Trading Service Connection and Symbol Issues
Date Time Of Last Edit: 2023-09-07 12:03:45
