Date/Time: Tue, 26 Nov 2024 12:28:49 +0000
Feature Request
View Count: 728
[2023-09-06 20:55:31]
User647607 - Posts: 15
I'd like to have a column in the Trade Orders window that shows the time that the TIF: Send At Time is set to.
For the MIT order type, when it gets sent to the DOM it shows as a Limit order. It would be helpful if this showed what it actually is. This creates confusion when there are multiple orders in the same area of different types.
Also, for the TIF:SAT order type, it would be helpful if there was a date function with the time.
[2023-09-07 18:26:04]
Sierra_Chart Engineering - Posts: 17179
This is now out in the latest release. The time is displayed in the same column.
The date is not supported. Only time.
Date Time Of Last Edit: 2023-09-07 18:26:26
[2023-09-08 00:06:14]
Thank you for the quick response.
Tonight I did a test to create an order at 18:00:00 but in the TIF column it shows Send Order At Time 01:00:00. I did another test at 19:05:00 and it shows as 02:05:00. The time zone in SC is set to Pacific which is the correct one. How do I display the orders in the correct time zone?
[2023-09-11 04:10:03]
We think the time you are seeing is actually UTC. We will look at this. For now though just understand that it is UTC.
[2023-10-08 02:52:24]
Today I tried it again and it appears that it may be UTC but it's also adding some time. In SIM I created an order to be submitted at time for 19:46 and it shows 05:14. Please advise.
Private File
[2023-10-10 19:59:46]
We will check on this again.
[2023-10-11 09:06:46]
Update to the latest prerelease to resolve this.
Instructions:
[2023-10-12 03:34:34]
It does appear to be working to list the orders at the correct time now, thank you. I'd like to be able to sort the orders in their chronological order of execution while they are in their held state. The sort order seems to focus on the Send Order At Time for the Time In Force column under Trade Orders window and doesn't include the time. It doesn't change anything when I try to sort the column. Is there a way to include the time in the sort order for that column?
[2023-10-27 06:01:45]
Is there a way we can adjust the sort function in the Trade Orders windows in the Time In Force column? When I click on sort it doesn't put them in order of ascending/descending times if I have several orders with the Send Order At Time TIF. It doesn't do anything. I can sort by the other columns. Thank you
[2023-10-27 16:57:27]
Sorting that column is not going to work like you want. It is not something we would change.
Date Time Of Last Edit: 2023-10-27 16:57:54
[2023-10-29 23:00:22]
My desire is to be able to sort the orders based on what time the order will be submitted to the exchange chronologically, not the sequence that the orders were inputted into SC. Is there another way to do this?
[2023-10-30 00:08:54]
This is not supported like this. The sorting is strictly based upon the Time in Force type which has an internal integer value.
[2023-11-27 17:06:19]
onnb - Posts: 662
Is this supported via ACSIL?
Meaning, is it possible to:
1. Submit orders with "Send Orders at Time"
2. Get this time from s_SCTradeOrder
[2023-11-29 19:13:18]
No this Time In Force type is not supported in ACSIL.
